Help wanted with Briggs Engine
Home › Forums › The Main Forum Area › General talk and discussion › Help wanted with Briggs Engine
Viewing 3 posts - 16 through 18 (of 18 total)
  • #3115
    it does appear to be an N Briggs. If the makers kept up the original numbering system, the tags serial number comes out to one built in July of 1942. To verify this is the correct yr, Briggs always stamped the last 2 digits of the manuf yr on the back outer edge of the flywheel. You should find a small circle there with a 42 in it. This will also work for their model 6 and 8 engines.
    #3161
    thanks guys for your replys, all very helpfull
    #3176
    I’ll have a look, I’m probably taking it to the Wessex Crank-up on December 1st at Nunney Catch near Frome….
