Home › Forums › General › Help and information › Wolesely clearway
- This topic has 29 replies, 5 voices, and was last updated 5 years, 5 months ago by
March 21, 2021 at 9:37 am #36815
vhgmcbuddyMemberMarch 21, 2021 at 11:44 am #36820
wristpinParticipantYours looks to be quite a “modern” version with a Kubota Mag engine. Not sure about the non “aspirated” version – predictive text ?
Anyway I have some Operator / parts manuals for what was then known as the Clearway HS 30” rotary grasscutter. 1973 onwards .
If these will be of any assistance I can scan them for you.March 21, 2021 at 1:01 pm #36822
vhgmcbuddyMemberYes please! I’m wondering if the kubota engine was a later retro fit? Anyhow any information would be helpful thanks!
March 21, 2021 at 8:11 pm #36823
dorignyParticipantI’m thinking that this one is pre the HS30 as there was I believe a mechanical drive earlier version…but then I’ve never actually seen a mechanical one. I suspect the engine is a much more recent swap.
C.
March 21, 2021 at 11:14 pm #36825
wristpinParticipantMarch 24, 2021 at 4:00 pm #36832
vhgmcbuddyMemberMany thanks for this!
March 27, 2021 at 1:36 pm #36841
vhgmcbuddyMemberOk my next question is, it currently only goes backwards when I engage the drive to the large wheel that goes into the gearbox… How do engage it to go forwards?
This is very puzzling to me…
March 27, 2021 at 1:49 pm #36843
wristpinParticipantI would presume that there’s a forward/ neutral /reverse shaft/lever sticking out of the hydrostatic drive unit that should be connected to a handlebar control lever.
March 27, 2021 at 2:18 pm #36844
trusty220KeymasterQuite right! There used to be a lever on the left hand handlebar that controlled the hydrostat. It sounds like your lever has been left in the reverse position so that when you engage drive to the gearbox it starts to move backwards. If you move the hydrostat lever to the middle position you will find it will stop the wheels rotating, and if you move it to the forward position it will move the wheels progressively faster in the forwards direction. The further forward you push the lever the faster forward it will go and if you bring it backwards it will get slower, then stop, then start to move in reverse.
Don’t run yourself over!
March 27, 2021 at 6:30 pm #36845
vhgmcbuddyMemberI cannot fathom how I still can get it to go forward? There is a lever on the right of gearbox which only selects slow (lever back), neutral (middle) or fast (lever forward)
The other lever that is on the left engages the belts and pulleys to spin the large grooved dish that clearly terminates inside the gearbox.. Maybe someone fiddled with it and put the gearbox back upside down ;0)March 27, 2021 at 7:14 pm #36846
wristpinParticipantHas it ever worked correctly in your ownership or is it a new acquisition ? If new to you , maybe there’s history . Worth checking that the “ handlebar” lever is properly set up/ located at the hydrostatic end and not slipping on the hydrostat’s selector shaft.
March 27, 2021 at 7:23 pm #36847
vhgmcbuddyMemberIt has never worked in my ownership, so am running blind at mo… What is this hydrostatic you speak of? I am not sure mine has this…
March 27, 2021 at 10:20 pm #36849
wristpinParticipantIf your machine has a belt from the engine or drive shaft driving a pulley with a fan on the end of a large finned lump, it has hydrostatic drive which gives stepless variable ground speed in both forward and reverse . An image of the mechanicals from the operator’ s position will clarify this. The finned lump with an oil reservoir on top is the hydrostatic drive unit – commonly shortened to the hydrostat.
March 28, 2021 at 8:55 am #36850
vhgmcbuddyMemberMine is pre-hydrostatic plus it has a ‘newer’ kubota engine on it which runs sweet… So far I have managed to service and have running most moving parts apart from the cabling from handlebars.
I’ll post some pics for you….
March 28, 2021 at 9:57 am #36853
wristpinParticipantWe need a few more images to see exactly what you have as your description doesn’t match any Clearway that I’ve worked on or have manuals for. Rather than being “ pre hydrostatic “ it could well be post hydrostatic as I know it.
