Home › Forums › General › Help and information › Wizard simplex pump
- This topic has 9 replies, 5 voices, and was last updated 6 years, 1 month ago by
trusty-mad.
August 29, 2020 at 2:13 pm #35320
trusty-madParticipantGoing through the shed the other day and came across this pump I forgot I had. I believe it is some form of irrigation pump and is marked as “wizard boil simplex”. I have tried searching this but google has not been very helpful in finding out more information. Dose anyone know anything about these?
August 29, 2020 at 4:03 pm #35324
alanParticipantB.O.I.L stands for British Overhead Irrigation Ltd. So can assume it’s from one of their irrigation systems, dating from the early 1950’s onwards.
Bits of info say that the Wizard Simplex was an oscillator irrigating crops 25′ to each side, does this sound right?
B.O.I.L were for many years based at Upper Halliford, Shepperton, Middlesex. I’ll quote the text: “They specialised in artificial rain equipment, the principle being the projection of jets of water in such a way that it atomises and falls naturally to simulate rain”.
August 30, 2020 at 7:19 am #35327
charlieKeymasterLooking closely at the photo it does say Shepperton.
August 30, 2020 at 10:28 am #35330
trusty220KeymasterHi, Robert,
How does the pump drive? I can see that it has two horizontally opposed cylinders with some sort of arm to make them move from side to side, but how does this arm move? A few more pictures may be helpful if you’ve got the time.
Thanks again.
August 30, 2020 at 11:27 am #35331
daveParticipantWe think that it worked off a pressurised system so the flow
of water kept the pump working. Probably in a overhead system
in large glasshouses or market gardens.August 30, 2020 at 2:10 pm #35332
trusty-madParticipantThanks for the information alan. With this I managed to find another post on the forum dealing with a different sprinkler but showing an advert for this one. Obviously I was wrong thinking it was a pump where it is apparently a sprinkler.
Geoff the central arm move side to side and has a toothed rack on it. This connects with a toothed gear below that actually makes the output shaft (photo 2) rotate side to side. I guess this is where the sprinkler head fits. I will take a couple more photos when I am in the shed next weekend.
August 30, 2020 at 2:15 pm #35335
trusty-madParticipantFor those that are interested here is the other topic.
August 30, 2020 at 3:32 pm #35338
alanParticipantI never thought to look at the VHGMC stuff, instead I looked through some magazines! That’ll teach me!
Many thanks for linking the two threads together.
August 30, 2020 at 3:35 pm #35340
alanParticipantA larger image of a BOIL advert:
September 5, 2020 at 3:28 pm #35355
trusty-madParticipant -
