Villiers two stroke
Home › Forums › The Main Forum Area › General talk and discussion › Villiers two stroke
  • #5986
    Hello I have a mk 25c , and after some help about petoil, in my book it says to mix half a pint (300 ml) of oil to a gallon of petrol. Castrol xl oil can I still get this or is there similar oil ? Or will my sthil two mix HD oil good enough at what mix?
    And would you recommend adding redex too?
    Thanks stu
    #6003
    Castrol XL is still available. When mixing fuel for my SIMAR 56 sometimes I use Castrol XL and other times a modern 2 stroke oil, but always in the ratio specified for the machine ie 6%.
    #6004
    Thank you Charlie, so I just use my high grade sthil Oil, but to the ratio for the engine, ie 300 ml to 5 litres off petrol.
    #6005
    Stew , under no circumstances use any modern oil such as Stihl , for your mixture. Any grade of STRAIGHT 30 grade oil should be used , my choice for all my vintage twostroke machines is Morris.
    On a 25C , the crankcase sealing will not work well on modern oils , your machine will run on them , but it will run far better on a straight 30 mixture.
    Hello Andy,
    Thank you, I have been and got ,a gallon of Morris ground force, sae 30 oil.
    So going on my Villiers book it says half a pint of oil to a gallon of fuel.or four measure’s with the cap.??
    #6011
    Stew , yes , if you’ve got the measuring tube fitted to the cap on your tank , it’s four of those measures to a gallon.
