Trusty tractor no spark
Home › Forums › The Machinery Forums › Pedestrian operated machines › Trusty tractor no spark
  • #10568
    hi, new to the forum and need some help.
    Me and my dad have just purchased a trusty tractor and it has no spark.
    checked and cleaned the points but still no spark.
    Are there anything else i can check before looking for a new ignition system?
    Its a briggs and stratton zz engine.
    Many thanks
    joey
    #10569
    joegrgraham
    Hi Joey,
    I have the same engine on my Trusty and had the same problem.
    I’m afraid it is probably the coil that is kaput, but it would be worth getting it tested first, just to make sure.
    You cannot get new coils for the briggs engine, but they can be re-wound. Private message me if you want contact details for magneto rebuilds.
    Joe.
    #10575
    sidevalve44
    There’s a chap in Idaho who deals in obsolete B&S parts. His name is Jim Freshman. email:- jim@aircooledengpts.com
    I bought a new coil from him that B&S no longer make.
    Might be worth a try.
    Robert
    #10598
    How would I go about testing the cool.
    Does this chap in Idaho ship to the uk?
    #10603
    To test the coil properly you will need to find someone with a suitable tester, your local garden machinery repair centre may be able to help. Testing with an multi meter will only be able to identify open or short circuit, it will not show if there is low insulation which breaks down when coil is in use.
    #10616
    sidevalve44
    Joey,
    Yes he does, although his online ordering page doesn’t cover shipments outside the US. Ask him for a quote for UK shipment, usually about $9.25.
    Robert
    #10619
    pete0250
    I had trouble with a zz years ago and it seems the trouble was a slight oil leak from the crank seal which allowed oil onto the points. Might be worth checking. Good luck.
