Teagle hedge trimmer
Home › Forums › Groundcare Machinery › Teagle hedge trimmer
  • #38488
    jeremy-russell
    Good morning all,
    Information on purchasing a replacement drive belt, part number and belt dimensions would be greatly appreciated.
    Best regards
    Jeremy
    #38490
    hdtrust
    Dear Jeremy,
    If you have the original its quite easy, look up on google to you nearest belt distributor, there are many in most towns, they will be able to measure it correctly, failing that, if you have not got a belt, you need to measure, the length around the pulley wheels, I find it best using washing line. also measure the internal width of the pulleys, from there take the measurements to the same distributor
    When you have done that, I always buy a spare, for the price its not worth the heart ache of another breakdown
    Regards
    Andrew
    #38491
    I have had a look at the instruction manual/parts list and it only gives a Teagle pat number J24 and no indication of dimensions.
    #38492
    Best way is to measure shaft centre to centre , outside diameter of both pulleys , quote these figures to any reputable belt stockist , and they should supply you with the exact belt.
    dave
    I checked my Teagle Jetcut this morning. No numbers on the belt
    but it measured 27 inches round the outer of the belt. I hope that
    this is of use to you.
