Should allen scythe cutter bar be straight?
Home › Forums › The Machinery Forums › Pedestrian operated machines › Should allen scythe cutter bar be straight?
  • #28401
    Hi, just got hold of two allen scythes, A model T in poor condition but turns over and a model TS which runs although cutters corroded and out of adjustment, it will cut grass but stalls on 1/2″ twigs. Both the cutter bars are bowed about half an inch up towards the tips. Should the bars be curved or flat?
    Thanks.
    #28405
    I am pretty sure they should be flat with no curve.
    #28406
    ted20
    they must be flat otherwise would bind at end of travel if fingers are properly adjusted
    #28410
    Many thanks, I was unsure if the curve was some kind of preload, a little like scissor blades. I can now see the bend is just outboard of the three attachment bolts. Straightened out OK with a little ‘manual engineering’. Getting everything cleaned up now, cutter blades a little corroded but seem to have had little wear and sharpen up OK.
    Thanks again.
