Replacement parts for Villiers carb
Home › Forums › The Machinery Forums › Pedestrian operated machines › Replacement parts for Villiers carb
  • This topic has 4 replies, 3 voices, and was last updated 2 years ago by danh.
  • #43056
    danh
    Hi all, I recently brought a non-runner Mayfield cultivator with a Villiers mk15 engine. I’ve taken the carb apart which is a v508c/1 which I don’t think is original to the engine? It’s missing the float bowl valve needle which I assume looks like a brass pin?
    Could anyone point me in the direction for spare parts for this carb? Ive checked websites like Villiers spares and I don’t think this is an available ite. Alternatively, if anyone can recommend a replacement carb, either Villiers or non-genuine, that would be great! Thanks Dan
    #43057
    danh
    After first checking for British seagull Villiers carb spares (it seems v508c was more common on those?) I’ve come across this part:
    V355 Fuel Needle
    The length seems appropriate, can anyone confirm if that would be right part? Much appreciated!
    #43058
    t-max
    Hello DanH, are you able to look on ebay search villiers carburetors 3rd page I came across a whole host of needles with the 5 setting rings on top end, new old stock supposedly hope this is some use.
    #43059
    George shead at villiersparts will sort you out.
    tmax , we’re talking float needles here , not fuel needles.
    • This reply was modified 2 years ago by andyfrost.
    #43061
    danh
    Hi thanks both for the help. Tmax, eBay is normally my first go to and I did come across those needles with the grooves but they didn’t look right. Thanks for the suggestion though.
    Andy, thanks I’ll reach out to villiersparts. Cheers Dan
