Ransomes MG 40 Sachs 600L engine
Home › Forums › The Machinery Forums › Ride-on machines › Ransomes MG 40 Sachs 600L engine
  • #30953
    Hi Does any one know who can supply a piston with rings for a Sachs 600L diesel 2 stroke engine. I am getting the cylinder bored out so am unsure what size piston I will need but need to find where to get it from. Many thanks Bob
    #30954
    ransomes256
    Bob,
    As you already know I do not have Sachs pistons or know of a source (would like to know if you find one).
    As an alternative have you considered having the barrel sleeved so you can continue to use your current piston?
    Neil
    #30955
    premier
    Hi Bob, I have had pistons made by this company in the past.
    Speak to Duncan, I found him to be very helpful.
    F W Thornton – “The Automotive Parts Specialists”
    Orleton Lane, Wellington, Telford, TF1 2BG, Shropshire.
    Jonathan
    #30956
    Neil I should have said the piston is damaged and cant be used.
    Bob
    #30957
    Hi Jonathan thanks for the name of that company. I will get in touch with them to see if they can help.
    Bob
    #30958
    stuart
    Have you tried Cox and Turner engineering ?.
    #30960
    Hi Jonathan no luck with F W Thornton – “The Automotive Parts Specialists” thanks any way.
    Bob
    #30961
    Hi Stuart just tried Cox and Turner engineering and they can’t help.Thanks any way.
    Bob
    #30962
    ransomes256
    Bob,
    You could try sending an email to the Holder group in Germany who may know of a suppier.
    https://www.einachser.org/holder/index.html
    Neil
    #30963
    Sadly Cox & Turner are snowed under with work and are not taking on new work outside their core activities. They do have a huge stock of piston rings and can make rings if required.
