Ransomes marquis + kubota engine
Home › Forums › The Machinery Forums › Pedestrian operated machines › Ransomes marquis + kubota engine
Viewing 8 posts - 16 through 23 (of 23 total)
  • #25658
    Does anybody know how to adjust the gap between the ignition coil and the flywheel on this machine? The ignition coil is located at the inside of the flywheel.
    #25659
    stuart
    If the coil laminations are not slotted then there is no adjustment required.If they are slotted then it would be a case of using the “factory service tools” to set it up.
    #42427
    I have the Ransomes Marquis 51 with the Kubota G130 engine. I cannot find a replacement carburettor. Does anyone know where to buy one? thanks
    #42428
    Have you tried L$S Engineers.
    Andy
    #42430
    Andy, I have tried on there website with no success. maybe I should give them a call.
    #42431
    Yes , it’s worth a call , EG COLES in Dorset used to do some Kubota spares ,so maybe they’re worth a call also , as well as Small Plant and Garden Spares.
    Andy
    #42432
    thanks a lot
    #42491
    Andy, thanks for your help. EG Coles put me in touch with Hurley Engine Services where Jack was very helpful and I have a new carburetor and fuel tap on order. Contact details are 01225336812 or jack.braine@hurleyengines.co.uk
