Ransom mg6 starting problem
Home › Forums › The Machinery Forums › Ride-on machines › Ransom mg6 starting problem
Viewing 1 post (of 1 total)
  • #31369
    I have been trying to get my mg6 to start and run smooth but I am not getting any were.
    I have took the head of and turned the engine to tdc and set the crank shaft so the key way is at 12 o clock set the cam shaft so the key way is at 9 o clock
    I then turned the Magnéto shaft till it clicked and fitted the timing chain
    I have checked the Magnéto sparks at tdc
    But have noticed that the valve clearance is good on the compression stroke at tdc but not when on the other strokes
    I have fitted a new condenser to the Magnéto and checked the points
    But cannot get the engine to run
    The carburettor is getting fuel as I seem to be getting fuel running back to the air inlet hose
    I do get a mis fire now and then
    Any help would be appreciated
    I have had some help from some members and thank them
    Am I setting the timing correct
