Home › Forums › The Machinery Forums › Pedestrian operated machines › Orolo tracked barrow
- This topic has 10 replies, 4 voices, and was last updated 4 years, 5 months ago by
rpage.
April 29, 2022 at 3:01 pm #38903
rpage
ParticipantThis is owned by a friend with a tracked unit which was a joint venture between John Allen and Ford Ploughmaster tractors its dated around the 1930s its a wooden construction any information would be usefull
April 29, 2022 at 3:25 pm #38904aquila787
ParticipantDo you have photos. I dont know anything about it but I’d like to see it.
John
April 29, 2022 at 3:49 pm #38905aquila787
ParticipantFound this maybe you’ve seen it already. There’s a few photos there too.
Practical Machinist.believe this to be an “Orolo” track unit, or a copy of one. “Roadless – The Story of Roadless Traction from Tracks to Tractors” by Stuart Gibbard has this to say about the “Orolo” track unit.
“One of Roadless‘s first and most commercially viable ventures was the introduction of the Orolo track units. Originally designed for the British Admiralty to transport a 6 in. naval gun over soft ground, the Orolo unit consisted of a self-contained bogie with rigid girder tracks running around two or three rollers. The track was designed to be self-locking so that it would form a predetermined radius to give it the same performance as an extremely large diameter wheel with very low rolling resistance.
The Orolo units were available in several different sizes, and could be used in place of the wheel in a variety of applications, including bullock and mule wagons for Africa, India and South America, log carriers and lifeboat carriages – and the Roadless drawing books even show details of an Excelsior washing machine so equipped in 1932, but for what purpose is not known.
When the Orolo unit was first conceived, a scaled-down version was tested on Philip Johnson‘s garden wheelbarrow. So successful was this unit, that Roadless decided to put the tracked wheelbarrow into production. A couple of hundred were made towards the end of 1927, and it became a popular addition to the company‘s early product line. At the other end of the scale were the D8 Oro1o track units, introduced in 1929 and capable of carrying 12 tons per pair. The company eventually built units during the Second World War which would carry 20 tons on each track-bogie. The Orolo track units remained in production until well into the 1960s.”I can’t help but notice that at least two of the gentlemen at the John Allen & Sons (Oxford) Ltd. stand at the Royal Show are wearing spats.
The pub model(?)…
…and the export model(?). (Manufactured in 1929 by Khasia Sillimanite Company in India).
You can see one of the original patent documents for this type of track <here>.
G2 Orolo brought out in 1930 with rubber jointed tracks.
April 30, 2022 at 6:17 am #38906
charlieKeymasterMay 1, 2022 at 10:42 am #38917
trusty220KeymasterThey were also used on wartime searchlights to give them increased mobility. An example on tracks is in the Yorkshire Air Museum.
Another wartime use of the heavier type was for recovering crashed aircraft from inaccessible sites; a pair of tracks was used either side of a platform and the whole tracked trolley was placed under a strong point of a crashed aircraft to allow it to be towed to a more convenient place to be dismantled. It’s surprising how more mobile it makes a load just by lowering the ground pressure this way.
May 4, 2022 at 6:58 pm #38938rpage
ParticipantMay 5, 2022 at 6:35 am #38952
charlieKeymasterThe photos confirm it is like the wheelbarrow in the photo I posted.
I see the makers plate lists several patent numbers but can’t read them. It might be worth looking them up.May 5, 2022 at 4:50 pm #38956rpage
ParticipantCheers I will make contact with the owner and try and follow that up
Thanks again DickMay 7, 2022 at 1:36 pm #38965rpage
ParticipantMay 9, 2022 at 7:26 am #38986
charlieKeymasterMay 9, 2022 at 10:21 am #38993rpage
ParticipantHi Charlie,
Thanks for that I Have looked again
at the images of this and as far as I can see the
numbers all match up will check my phone and be in
touch
Many Thanks
Dick Page -
