Old Atco Mower 17" cut
Home › Forums › General › Help and information › Old Atco Mower 17" cut
  • #8952
    I am restoring an old Atco machine, 17″ cut, and am keen to find out as much as I can about it. If anyone has any information I’d be grateful!
    The machine number on the brass tag is 1760/61
    The engine has a tag on the cover that says Serial 800C 71671
    The carb. is a Villiers so I assume the engine is as well
    The engine has a kick start arrangement rather than a pull cord.
    I’d like to know what model it is and what the engine and machine numbers mean, plus if any spares are available etc.
    Thanks in advance!
    Chris
    #8956
    stuart
    I believe the 61 at the end of the serial number is the year of manufacture so it would be a 1961 model.
    The 17 at the beginning of the serial number may mean its the 17″ model but im sure someone else on here may be able to verify the above.
    #8966
    I would agree with that interpretation of the chassis tag numbers but no idea whether the engine numbers indicate a date of manufacture. As for parts, auction sites and auto jumbles.
    #8969
    stuart
    Chris….if your Villiers engine has a “headless” cylinder (cylinder and cylinder head cast in one piece) and has sloping cooling fins then i have a complete engine available.It was running perfectly when i removed it from the mower a few years ago.
    #8970
    Yes it is a 17″ machine dating from 1961. Spares for Villiers engines are available from a number of suppliers, eg Meetens, Villiersparts etc
    #9443
    hdtrust
    Don’t forget that well known supplier of parts and manuals, sweating away in a cave in deepest Somerset, none other than Mr Wallingfield!
