Motorised barrow identification
Home › Forums › The Machinery Forums › Pedestrian operated machines › Motorised barrow identification
  • #33502
    I recently purchased, from a late friends estate, this motorised barrow. It is fitted with a Petter AA-1 engine. Can anyone identify it please?
    Also, I would like to know the type and quantity of lubricating oil that goes into the axle.
    Many thanks.
    No idea as to the maker but a “ smell test” will establish whether the axle has an EP oil in it or just a straight oil. Which ever, you will probably be safe with either an EP 80/90 or a straight 80/90. Unless, that is, you can identify it has worm drive. If worm drive it will need an oil specifically for that application.
    Hopefully someone will identify the machine and lead the way to a specific answer.
    #33539
    dorigny
    Have a Google for BarOmix power barrow…the photos I found look similar.? less the back skip extension.?
    C.
    #33544
    Thank you dorigny, that is indeed my machine.
