Mg2 carb
Home › Forums › General › Help and information › Mg2 carb
  • #30546
    Hello I’ve just purchased a MG2 should there be a spring below the strangle knob on the carb to hold it up? It’s currently just at the bottom I can turn it to the right and it stays down and stays in same place when undone thanks Stuart
    #30548
    ransomes256
    Stuart,
    Yes there should be a return spring and also a small clip that fits around the rod in the slot of the top cap. The clip allows the rod to turn to the groove allowing the strangler to stay down against the pressure of the return spring.
    Neil
