Mayfield cutter/scythe belt size
Home › Forums › General › Help and information › Mayfield cutter/scythe belt size
  • #10247
    Hi, Could someone kindly give me the belt size for the above front belt from engine pulley to bar pulley do you need two? Also would a older cutter bar fit or could be modified to fit a more modern allan mayfield with a kohler engine Regards Rob
    #10254
    hortiman
    Hi there
    I suggest that you message ‘merlinkeeper’ who is a regular on this forum, he is into mayfields in a big way.
    Chris
    #10255
    Thanks Chris will see if i can contact him Cheers Rob
    #10793
    merlinkeeper109
    MK 15 need 2 M39 belts
    #10822
    Thanks for the information Ive got two machines A4118 and c1209 which i would like to run a cutter bar on any history on these and belt sizes for both please .Thank you for your time. Regards Rob
    #10823
    merlinkeeper109
    A4118 1965 series 9 cutter unit A40 belts
    C1209 1960 series 9 cutter unit A46 belts
    both machines are croft Mayfield’s
