Mayfield 2 wheel tractors
Home › Forums › The Machinery Forums › Pedestrian operated machines › Mayfield 2 wheel tractors
  • #27566
    Happy New Year to you all.
    Does anyone know of anywhere which refurbishes Albion gearboxes – it’s something that I really don’t have any confidence in.
    I’ve just bought this machine, started stripping it back & the gear lever is quite slack making the selector difficult to go through the gears.
    Any suggestions will be gratefully received. Thank you.
    #27567
    rollomk6
    Hi Mayfield check the bottom of the gearchange lever as this hole with two flats often gets worn on the flats and you end up with a very sloppy gear change I have two Mayfields and they both were badly slotted out but with a welder and flat file these were easily repaired it made such a difference to the gear change hope this helps
    #27568
    Possibly try a vintage motor-cycle forum, such as
    https://www.classicmotorcycleforum.com/
    #27655
    Thank you to both of you, sound advice from both angles, most appreciated.
