Home › Forums › The Machinery Forums › Pedestrian operated machines › Landmaster 88 with Aspera motor.
- This topic has 8 replies, 2 voices, and was last updated 4 years, 11 months ago by
sidevalve44.
September 19, 2021 at 4:57 pm #37891
sidevalve44ParticipantWell, I’ve got the engine going, it started pretty well straight away but, it runs flat out only.
Is this normal on one of these ?
I’ve connected everything up as it was before and apart from cleaning, haven’t touched the carb, so I’m assuming this is how it should be.
It also leaks fuel from the tap and the float chamber drain tickler so, a few more new parts needed !
September 19, 2021 at 7:51 pm #37892
wristpinParticipantSounds as though someone may have messed with the governor, hopefully only the external linkage and not a problem with the internal mechanism. A decent image of where the governor shaft emerges from the crankcase and the arm clamped to it will help with suggestions for resetting it.
September 19, 2021 at 8:50 pm #37893
sidevalve44ParticipantOne reason why it may have been running flat out was I had not connected the gearbox. It has no clutch, so the drag of turning the gears would of course slow it down a bit.
September 20, 2021 at 1:45 pm #37897
wristpinParticipantOne reason why it may have been running flat out was I had not connected the gearbox. It has no clutch, so the drag of turning the gears would of course slow it down a bit.
Na, erroneous thinking! Correctly set up that engine should start, idle and run at full throttle under governor control with no external load. Let’s see a decent image or two of the governor / throttle linkages.
September 20, 2021 at 5:51 pm #37898
sidevalve44ParticipantI think I may have cracked it. The Governor arm can be adjusted a little on the spindle to the left or right. I had a look and found it was too far to the left, meaning it was holding the throttle open at all times regardless.
I slackened the screw and it moved slightly to the right and immediately the throttle shut. Operation now seems to be normal. It had probably got knocked at some time.
Haven’t run the engine to try due to the fuel leaks, but I’m pretty certain it’ll be alright now.
Thanks for the advice, it pointed me in the right direction.September 20, 2021 at 8:17 pm #37899
wristpinParticipantThat’s good, as I suspected. The movement of the arm on the shaft is a basic setting, not an adjustment, meaning it’s either correct of incorrect – no partially correct. The usual procedure is as follows, but consult the workshop manual wherever possible.
Slacken the clamp just enough to allow the shaft to be rotated. Then move the governor arm to give full throttle on the carb. Then holding the governor arm to maintain that position, turn the shaft fully in the same direction direction that gave full throttle and fully tighten the clamp.
That will give the full governed speed for any throttle lever position. The principle is that when the engine is running the internal governor mechanism is always trying to close the throttle, that action is opposed by the throttle lever via the governor spring, the result being the governed speed.September 20, 2021 at 8:48 pm #37900
sidevalve44ParticipantThanks.
After I get the new fuel tap etc. I’ll run her up and see how she performs and adjust as necessary.
One thing I did notice when I ran it yesterday was how noisy it was, even with a new “silencer!” (Tiny little pepper pot thing with about one baffle !)
September 21, 2021 at 1:12 pm #37901
wristpinParticipantIf your tap has a “ gland nut” a fraction of a turn may cure the leak. Also it used to be possible to buy a new “ packing” for the spindle – similar to old plumbing taps. In the past I’ve effected a temporary repair using a bit of well greased starter cord as a packing.
September 21, 2021 at 7:49 pm #37902
sidevalve44ParticipantHi Wristpin,
Jon Cruse has advised he should have the parts to repair the fuel leak. I’m waiting on him for a price.
Re. The governor. Am I correct in interpreting what you said as meaning, the governor should be holding the throttle wide open when the engine is not running ?
I have since found out that the metal cover that goes over the top of the carb was fouling the operating rod from the governor arm and stopping it from moving. I’ve fixed that issue, I just need to reset the governor. I’ve noticed that the spindle is square so it is not possible to rotate the arm on it. The arm is attached to the spindle via a bracket and screw that can be slackened off to enable the position of the arm relative to the spindle to be altered.
Most of my prior experience has been with B&S air governors, so this one is a new experience for me ! -
