Howard rotavator difference
Home › Forums › The Machinery Forums › Pedestrian operated machines › Howard rotavator difference
  • #30878
    Please can someone tell me how I can tell if I have a howard bantam a 220. The model I have has handles that can be offset, so I believe it must be one or the other. It has been retrofitted with a Briggs and Stratton 3HP model 80202. Would also appreciate any info on where I can buy a new or refurbished carburetor for this engine.
    #30879
    The rotors on a 220 are centre driven , and side driven on the Bantam , both share almost identical handle bar systems.
    Does it need a complete carburettor? Parts to service and overhaul the old carb may be available at Briggs and Stratton Parts or Briggsbits Another possible source is Meetens
    If you need a parts list try Briggs and Stratton website
    #30885
    Hi Andy, thanks for your reply re centre driven or side driven rotors, but as I know nothing about motivators and have just inherited this vintage howard, could you explain a little further please. Many thanks and regards, James
    #30886
    From photo gallery pages of this website, Howard Bantam with drive shaft along side clearly visible and a Bullfinch which has centre drive to rotors, couldn’t find photo of 220.
    #30888
    James , best to follow Charlies links , a picture would probably explain matters clearer, or even better post us a pic of your machine.
    Hi Andy, did what you suggested and it is obvious I have a howard bantam. Many thanks to you and Charlie for your help. Best regards, James
    #30903
    Another result then , Bantams are great little machines IMO , I have two , and they get used very regularly.
