Help/advice required to start my mg crawlers
Home › Forums › The Machinery Forums › Ride-on machines › Help/advice required to start my mg crawlers
  • #29223
    mollie1
    I have an mg 5 and 6 which I am trying to get running neither has run for a couple of years. Both now have clean fresh fuel reaching the carb but neither has a spark. Both were running fine before I parked them up. Any advise or suggestions as to why and how to resolve please.
    #29224
    Have you cleaned the points in the mag?
    #29228
    mollie1
    Tried points this evening still no spark. I’m going to try a new HTC lead tomorrow
    #29232
    ransomes256
    The chances are that both condensers have failed. Very unlikely anything to do with the HT lead. Trust the tractors were stored in a relatively dry place or damp in the magneto may be causing a short in the LT side.
    #29259
    mollie1
    Managed to get the mg 5 started with help from some fellow members at Weeley working weekend. It turned out to be a poor connection ht lead to plug cap. Also has an issue with the carb it has a replacement plastic float which leaks on the joint, sinks and causes major fuel loss. Anyone know any hard plastic glue that is petrol resistant
    #29260
    You may be able to seal the float by the careful application of a soldering iron to melt the plastic into the gap.
    #29278
    Try Araldite. Sets nice and hard and is petrol resistant.
