Home › Forums › General › Help and information › gang mowers
- This topic has 7 replies, 5 voices, and was last updated 6 years, 4 months ago by
trusty220.
June 11, 2020 at 3:13 pm #34678
martin-ellison
Participantdoes anybody know of yellow gang mowers— I used to work for college 1980s
set of 5 trailed mowers use to hook up behind one another for road transport—frames were all yellow thanks martinJune 11, 2020 at 5:30 pm #34683
wristpinParticipantIt was quite usual for trailed gangs to hook up in that way; sometimes in reverse orientation so that in the absence of mechanical disengagement the cylinders were not driven during transport. As for yellow, I’ll leave that to someone else. Other clues that may help with identification are whether “ your” set did have disengagement levers on the wheel gearboxes and whether they were on rubber tyres or studded steel wheels.
Common makes were Ransomes, Lloyds and Shanks ; and possibly others that I’ve forgotten about.June 11, 2020 at 11:38 pm #34696martin-ellison
Participantthey were in constant drve all the time even when you took them on road
when mowing 2 across front 3 across back
when on road they all went in single file you only could only go slow like pulling a snake
next time in Harrogate might go see if there still thereJune 12, 2020 at 8:07 am #34700
dorignyParticipantThis has made me think of a photo, maybe in a brochure or even IOG show booklet..can I heck as find it…!
Thinking maybe of the prof’ gangs once in the Atco range, were they yellow around the time of Wolseley Webb acquisition to match the rest of the prof range.??C.
June 12, 2020 at 8:35 am #34701ted20
ParticipantMartin have you thought they might be ex council yellow, at one time I had a yellow Howard Gem which was road registered (ex-council ? ) Dave
June 12, 2020 at 9:04 am #34703martin-ellison
Participantgood call suppose they could be
June 12, 2020 at 9:09 am #34704martin-ellison
Participantjust reminising the other night and somebody asked what sort of mower I was using narrowed it down to 1978 when I worked there but as you say could be atcos then painted
June 12, 2020 at 2:53 pm #34716
trusty220KeymasterMost of the mainstream gang mowers would have cylinders that would disengage and were all painted green in one shade or other.
As you say, Ransomes, Lloyds, Shanks and Greens were the common makes and they may have painted them yellow to match the rest of the local authority fleet. We used to have to spray Ransomes 213D’s yellow for Coventry City Council in the 1980’s.
Have you thought that with the yellow colouring they may have been Sisis- not many about and not certain how many were made but definitely a possibility.
