Diesel Injector Overhaul?
Home › Forums › General › Help and information › Diesel Injector Overhaul?
  • #24174
    Hi, i’m looking for a firm that can overhaul the bosh injector in my Sachs 500 diesel engine.
    Any suggestions? Many thanks.
    #24175
    Injectors tend to be made by a specialist company (such as Bosch) and are normally standard items which the engine manufacturers buy in. Most diesel service centres should be able to tackle the job; your best bet is to Google your local diesel service centre.
    #24181
    joegrgraham
    I’ve had good service from a company called ‘diesel Bob’, if I recall, they are in Lancashire.
    I remember sending him some injectors from an allis chalmers, he stripped them, then phoned with a breakdown of the parts needed and costs before doing anymore
    #24185
    Thank you to you both. Do you have Diesel Bobs contact number by any chance?
    #24188
    joegrgraham
    I don’t have a number, but he always used to advertise in T and M magazine, good old Google should come up with something.
    #24189
    Any decent fuel injection specialist should be able to overhaul your injector. If you remove it from the engine and put the business end into a jar or bottle you can observe the spray pattern or lack of it and note whether it dribbles.
    Be aware that a mishandled injector can force diesel under the skin with serious consequences.
    #24191
    My biggest problem is getting to the local places during working hours as I’m allways stuck at work so I have contacted diesel Bob and he seems very knowledgeable and fairly priced so after spending a couple of hours getting it to part company with the head it is now packaged up. There wasn’t much creak when turned over so I hope this should drastically improve things.
    #30330
    Probably too late this time round but there is a great article here about how to test and overhaul diesel injectors here:
    https://www.anglo-agriparts.com/diesel-tractor-injector-testing-overhaul
