Home › Forums › General › Help and information › Classic Hayter
- This topic has 8 replies, 7 voices, and was last updated 5 years, 6 months ago by
April 14, 2021 at 6:51 pm #36931
montyParticipantApril 14, 2021 at 7:48 pm #36933
charlieKeymasterIt may be worth contacting Hayter with the machine serial number they may be able to help.
I have a very similar machine which I still use, not in such good condition.April 15, 2021 at 8:30 am #36936
will-haggleParticipantThe engine number should give you the date to the day when the engine was built. Their website should help to decipher it. https://www.briggsandstratton.com/eu/en_gb/home.html
April 15, 2021 at 11:17 am #36937
hillsiderParticipantI doubt that Briggs and Stratton will be much help if the engine shown in the photo is the one in question. The engine shown is a European (Italian) built Tecumseh the Tecumseh manual that I have only seems to give engine dating information for American built engines.
April 15, 2021 at 12:43 pm #36947
wristpinParticipantHi all, anybody any idea of the manufacture year of this outstanding vintage Hayter?
No disrespect but it’s neither outstanding or vintage. It’s a bottom of the range 16” Harrier with the cheap engine option , correctly identified by Hillsider. Could even be the down specced version sold through the Sheds or mail order outfits.
April 16, 2021 at 7:17 am #36948
charlieKeymasterWhat is vintage? A 1980’s machine could be 30-40 years old now.
If this mower is that old then it is in very good condition.April 17, 2021 at 10:51 am #36966
alanParticipantI know someone who has one of those Hayters mowers with the Tecumseh engine but with electric start – it may be a slightly different model/spec but it’s similar. I have to say it’s not in as good condition as the image by the original poster.
As Charlie has mentioned; What is vintage? I’d also add that some of the lower-spec machines of any manufacturer can, but not always, be the rarest. I’ve often wondered how many mass-produced mowers, rotavators or tractors were made – was it in the hundreds, thousands or tens of thousands?
April 17, 2021 at 5:20 pm #36967
dorignyParticipantI have a low-ish serial number model 306 Harrier 41 autodrive and that I believe to be 1989.
Mine has the finger trigger height adjuster not a screw type as on the machine in photo. It does though have the same engine. No OPC, which I believe was reqd by 1995.I also have a Harrier 48 from 1987, which has the height adjuster similar in operation to the type on the machine in photo and has lost its adjusting knob, the same, leaving just a hexagon.. The rear flap is of the same style as my 1987 48cm mower, with the triangular ends overhanging the chassis side.
So I will have a stab at 1987/88..unless, as suggested, a model has been assembled at another time to suit a “Shed” price, but still pre 1995.
C.
April 17, 2021 at 6:25 pm #36968
charlieKeymasterThe one I have was electric start, but I have not bothered replacing the battery which died years ago. It has the screw type height adjuster.
