Home › Forums › The Machinery Forums › Pedestrian operated machines › bmb ploughmate
- This topic has 8 replies, 7 voices, and was last updated 12 years, 4 months ago by
February 1, 2014 at 7:18 am #5590
Anonymous
Inactivegood morning all
could anyone help me out please,i have a bmb ploughmate with a briggs and stratton zz engine which is poorly,need to get my hands on a barrel and a carbureter for this engine,as would like to keep it as original as possible,
does anybody know of any ploughing competitions with the walk behind tractors in the lancashire or merseyside area
many thanksFebruary 1, 2014 at 10:02 am #5591
chapParticipantSorry i am no expert on the ZZ but with ref to ploughing matches look at the Society of Ploughmen web site Local matches most will run a horti class http://www.ploughmen.co.uk/
hope that helps.February 1, 2014 at 12:04 pm #5592
charlieKeymasterIt might be possible to save the bore by having it honed.
February 1, 2014 at 3:41 pm #5605
joegrgrahamParticipantI’ve just finished the B + S ZZ engine on my Trusty. Carb’s do turn up on a certain auction site, and if you go on the .com (US) version of said site, you will find plenty of people offering carb kits. I got one from the US, N.O.S including postage cost about £25 and only took a couple of weeks to arrive. If you’re interested, PM me and I’ll pass on a couple of sellers who supply parts.
Joe.
February 2, 2014 at 11:57 am #5633franktonpaget
ParticipantThe B&S ZZ engine was fitted to early production BMB Ploughmate’s
A publication which may be helpfull to you is The Motor Traders Service Data sheet No 116 “Servicing the BMB Tractor” published in October 1942 gives data on engine and complete machine.
Postwar American built B&S engines were not used in cash strapped UK by BMB and particularly after devaluation of pound against USA dollar also became much more costly.
You could fit the alternative and much more readily available JAP 5 engine used by BMB in the ploughmate to get ploughing until you restore your B&S to working condition .
regards FPFebruary 4, 2014 at 7:05 am #5682Anonymous
Inactivethanks for your advice,in the process of looking at a jap engine could you please help me out again,the engine is approx 18 inch high by 10 inch by 10 inch,no numbers on any casings or engine,is this the 5,6 or 55 model,any help would be appreciated,thanks
February 4, 2014 at 9:03 am #5686
charlieKeymasterThe 55 is a two cylinder engine.
June 12, 2014 at 3:31 am #8610
vhgmcbuddyMemberHi there
seems like we may have similar machines as currently mine is fitted with a Honda engine but fortunately the chap i bought it off kept the Briggs engine tucked away under the bench as it had a broken exhaust valve luckily i managed to locate one from our neighbours in the USA and am now awaiting said item to arrive so then i shall be able to refit the beast with her original heartJune 24, 2014 at 9:38 pm #8773
vhgmcbuddyMemberHi there I havealso a bmb plowmate but mine has a 6hp map engine which has a trailer instead of the plow as the last owner removed it all and made the trailer,my bmb has the spiked twin wheels which I am looking to replace with rubber tyres as I an not using it to plow with.
