Albion 3 speed gearbox
Home › Forums › The Machinery Forums › Pedestrian operated machines › Albion 3 speed gearbox
  • #34631
    Hi recently purchased a Kohler engined Mayfield, the gearbox won’t shift at all, when you try it shows movement on the main shaft horizontally, are they fairly simple to rebuild or adjust?
    John
    #34638
    The Albion gearbox is a very compact design, they can be dismantled and rebuilt but I would not recommend it without a manual. Do you know which model of gearbox it is? I do have some manuals.
    #34832
    When you strip off the clutch fittings you will see that the toothed wheels are seperated with cork discs, often they are rusted together, soaking them in “Brick Acid” overnight will clean them up, before you tackle the gear box internals.
    #34836
    bigvic
    if you disconnect the cable watch that you don’t lose the ball bearing at the end of the compression shaft when the lever flips round.
