Home › Forums › General › Help and information › Villiers engine on Anzani Lawn rider
- This topic has 8 replies, 3 voices, and was last updated 8 years, 1 month ago by
January 21, 2018 at 2:06 pm #27721
vhgmcbuddyMemberI have just purchased my Lawnrider knowing that it had been left for years and didn’t run
I have checked over the mag cleaning the points and checking the capacitor but can’t be certain that the timing is right as I couldn’t find any instructions.
The carb was badly blocked up but both the jets are now cleared and flowing test fluid. It does need a new gasket that I have ordered.
I can get it to fire and sometimes multiple fires so the ignition can’t be far out but it will not run
Help pleaseJanuary 21, 2018 at 6:10 pm #27727
vhgmcbuddyMemberUpdate on above
After many many pulls the number of fires increased until it ran for at least a minute before stopping. The throttle was fully open but the speed only rose a small amount and the governor flap did not attempt to operate.
Suspect it maybe significantly retarded.
There is an arrow on the flywheel which I have aligned to TDC as there is no marker to align it to anywhere on the block or crankcase as far as I can seeJanuary 21, 2018 at 6:20 pm #27729
vhgmcbuddyMemberJanuary 21, 2018 at 10:53 pm #27737
wristpinParticipantLooks like a Villiers Lightweight, see if this helps
https://www.dropbox.com/s/6w8hkrr7k14y8od/Villiers%20Lightweight%20overhaul0001.pdf?dl=0EDIT sorry it won’t!! I’ll sort something else out.
This should!
https://www.dropbox.com/s/gnqkmtpxpx6yay9/Villiers%20Lightweight%20ignition0001.pdf?dl=0January 21, 2018 at 11:33 pm #27739
vhgmcbuddyMemberMany thanks for this. It certainly looks a lightweight. Does it have a numbertype other than 512/515 there is plate on it saying 103E I think
The timing info was useful but didn’t give the actual values for this engine. I think the data is on page 7. Any chance of sending ?January 22, 2018 at 12:20 am #27740
wristpinParticipantTiming data etc
https://www.dropbox.com/s/9xr8b7gkavl2x4e/Villiers%20lightweight%20data0001.pdf?dl=0Sorry, had assumed that you would find the marker on the back plate.
January 22, 2018 at 8:35 am #27741
vhgmcbuddyMemberThanks, you are a life saver for my machine
January 25, 2018 at 6:05 pm #27753
vhgmcbuddyMemberThe engine very occasionally will now burst into healthy life but stop after a few seconds otherwise it won’t start
Spinning it with my electric drill shows that spark voltage is only 4kvolts. Seems far too low to me. Apart from a new mag coil (25055) is there any cure?
And if not where can get a good one from?January 26, 2018 at 10:13 am #27763
charlieKeymasterI have found if a magneto is suspect it is far easier to change coil, condenser and points all at the same time. A more expensive way to solve problem but it does mean everything is new and should give years of trouble free running. Also only requires setting timing once.
