Home › Forums › The Machinery Forums › Pedestrian operated machines › Stupid thing has happend
- This topic has 7 replies, 3 voices, and was last updated 7 years ago by
roatavator.
February 17, 2019 at 3:16 pm #30375
carlharperParticipantHi all just got simar out of its shelter
Today and a leak in shelter side has fild up the engine full of water.through the exhaust
Have drained the water out do i take the spark plug out and then fill the engine with oil then drain out. Engine still turn over. ?February 17, 2019 at 4:24 pm #30376
roatavatorParticipantHi Carl. I’ve never had this happen, but if it did I’d be tempted to remove plug and spin engine over several times. Then a squirt of oil in cylinder, spin over again, clean plug and try to start and if it goes leave it running for a good time to throughly warm up. After stopping immediately open drain tap to let oil etc out. I’m thinking the sooner you get it running and oil circulated around, the less chance of internal corrosion. Charlie, I hasten to say, may well know better!
Stable doors and horses, but I put an empty dog food tin over all my SIMAR exhausts to stop water getting in when in storage.
PeterFebruary 17, 2019 at 10:46 pm #30379
carlharperParticipantProblem is just got back from dads working all day tomorrow back aftér dark
Tuseday will be the day to start up. Not making this misstake again.February 18, 2019 at 7:43 am #30380
charlieKeymasterI would open or remove tap and drain crankcase, which it sounds like you have already done. Getting the engine running and warmed up to drive out last traces of moisture and lubricate everything would be next priority.
After winter layup I strip and clean carb before attempting to start engine.
I always park SIMAR with front of machine on the floor and handlebar up in the air as recommended by Geo Monro this prevents water getting down exhaust, see attached.Attachments:
February 18, 2019 at 8:01 pm #30417
roatavatorParticipantInteresting Charlie. I have tried following the recommendation in the past but the gearbox oil seemed to drain into the engine causing problems starting in new season. I know, I should get around to renewing seals!
February 19, 2019 at 7:09 am #30418
charlieKeymasterYes I find some does get into crankcase but it does drain out when tap is opened.
February 19, 2019 at 2:28 pm #30425
carlharperParticipantGot simar running today all is ok . Had enough fuel for 10mins of run time . Egg cup of water came out but exhaust manifold has craked more
It has been welded in past.
Will run a weekendFebruary 19, 2019 at 7:42 pm #30427
roatavatorParticipantThat’s great to hear Carl. Tough old machines, these SIMARS. Hopefully you will get manifold repaired ok.
