Home › Forums › The Main Forum Area › General talk and discussion › petter a1 carb 24t2 ?
- This topic has 8 replies, 3 voices, and was last updated 3 years, 6 months ago by
shiftlessguy.
August 4, 2022 at 6:35 am #39630
shiftlessguy
ParticipantHey from across the pond.I have a petter a1 with a zenith 24t2 carb thats havin some issues.Carb was cleaned in an ultra sonic cleaner.The question i have is i think its missing an air bleed jet.Main jet us unknown as previous owner botched it a bit,slow jet is a 45 i need to confirm if its missing the other jet and if so whats the number for that air bleed and a good place for that part.Thanks in advance!
August 4, 2022 at 2:09 pm #39640shiftlessguy
ParticipantForgot to add 3hp petrol version
August 4, 2022 at 3:05 pm #39641andyfrost
ParticipantThe 24T2 is a very widely used carb , I don’t have the info at hand , but it is available , it will give you the jet numbers according to varying applications.
One tip is to disregard the main jet and replace it with the variable one , you can then compensate for wear in the butterfly ,(within reasonable limits) which is a common fault. Google up Zenith spares and you should find a host of suppliers of spares.Andy.
August 4, 2022 at 3:10 pm #39642shiftlessguy
ParticipantYa mine has the vari main jet.
August 4, 2022 at 3:23 pm #39643shiftlessguy
ParticipantHas a choke of 14,ya ive googled a bit but no specific #’s on jets
August 10, 2022 at 1:28 pm #39704shiftlessguy
ParticipantAny luck on the jet size
August 14, 2022 at 12:07 pm #39725
trusty220KeymasterJust in case you haven’t found it yet, for a Zenith with a 24T2 fitted with a number 14 choke tube the correct size for the air jet which fits in the hole you’re pointing to is 1.50, with the slow running tube (or jet) next to it being 50.
Don’t forget that you can fine tune the tick over with the Air Regulating Screw on the side of the venturi in the top cover of the carburettor. Remember that it adjusts the air part of the mixture, not the fuel, so screwing it out makes the tick-over mixture leaner (less fuel) and screwing it in makes it richer (i.e. more fuel).
Best of luck with it.
August 15, 2022 at 1:12 pm #39734shiftlessguy
ParticipantThat could be where the prob is thinkin its a fuel adjust.In talkn to others about alot if them dont have the comoensating jet,my setup has a #45 slow jet.so wondering if this setup doesnt require other jet.noboby seems to have the c1048 soec carb and no info on it either,although its very similar to other carb setups,thanks for the air screw info.Only kits on this side of ponx are the massy ferguson carb setups,and every place icer seas are out of kits for petter carb kits.
This reply was modified 3 years, 7 months ago by
shiftlessguy. Reason: more info
August 26, 2022 at 1:01 pm #39854shiftlessguy
ParticipantOne other thing that maybe affecting engine is that fir what ever reason theres a resistor plug on engine.Ive read that an engine that didnt have an R plug to begin with,the R plug will retard timing and spark is not as intense,in watchin a vid or recommended plug is ngk bp6es,nothing over here that will even cross with ut do itll be a coupla weeks before i get 1.Also just an fyi my engine didnt have any starter with it so i put a 7″ pulley on pto side,coulda made a ratchet starter but i like rope starts a bit more friendly especially if it back fires on startup.Orignial sediment bowl and plumbin was f’d up a bit from previous owner so had to put a fuel stop and filter.I will get a pic or two up soon.
