Home › Forums › The Machinery Forums › Pedestrian operated machines › Oxford Allen no power
- This topic has 10 replies, 6 voices, and was last updated 7 years, 7 months ago by
July 18, 2018 at 7:44 pm #28847
vhgmcbuddyMemberI have an Oxford Allen serial number 95671 with 2-stroke Villiers motor. It starts and runs reasonably well but will not rev and cuts out when asked to do any work. Can anyone give me some advice on how to sort this problem? Many thanks
July 19, 2018 at 9:05 am #28848ted20
Participantcould be coil giving warning of giving up, does it cut out suddenly or stutter ? if stutter I would look at carb. Villiers electrics sometimes give good spark until put to work then there is no resistance hence engine cuts out try simple things first like spark plug, condenser etc.
July 19, 2018 at 9:09 pm #28855rollomk6
ParticipantHi martyn -c also check your ignition timing as it is very important with a two stroke
August 14, 2018 at 5:58 pm #29100
vhgmcbuddyMemberquick update
have carried out timing check again and again pretty sure its good. have cleaned carb til it shines 🙂 but still no improvement. plug is new. latest thing i have noticed that after around 2/3 throttle it actually gets worse, which leads me to think fuel shortage. is fuel getting into bowl quick enough? wrong needle? wrong float?or what size should main jet be? as you can see clutching at straws now.
any help or thoughts appreciated or anyone with working carb near derby?August 14, 2018 at 6:45 pm #29101andyfrost
Participant“IF” you,re absolutely certain the timing is correct , as it has been mentioned previously , it is vital on Villiers twostrokes.
You have now got to investigate both the crankshaft seals , and cylinder bore/piston rings , unless it’s a very late 25c , the crank seals will be the gland bush type.Andy.
August 15, 2018 at 11:08 am #29107
merry-tillerParticipantGradual flywheel slippage affects (retards) the timing and although it may have been perfectly assembled to start with it can end up too retarded to do any real work. I used degreaser, flour paper on the shaft to dull the finish then some Loctite. It lasts about a year before I have to redo it! Why Allen didn’t key the shaft at the correct timing only they will ever know!
August 15, 2018 at 4:01 pm #29108
charlieKeymasterThe secret to stopping flywheel slip is degrease and clean both parts of taper then tighten flywheel properly. Villiers supplied a special ring spanner for this with a large lump on the end so it could be hit with a hammer.
August 15, 2018 at 5:48 pm #29110
vhgmcbuddyMemberthanks all
have snowpeaked the timing marks to make it easier to check and all still seems to be good, degreased taper every time. andy are you thinking it may not be ‘sucking’ enough? this would surprise me as put hand over carb when running and it ‘sucks’ 🙂 . still puzzled why it would get worse when throttle goes above 2/3, makes me think too much air not enough fuel, does anyone agree? still open to any or all suggestions. will defiantly get this sorted. hopefully!!!August 16, 2018 at 8:27 am #29118
charlieKeymasterI never use the timing marks on Villiers engines. I always set timing by setting piston at correct position eg 1/8″ BTDC for a MK15, then set flywheel so points are just opening. Checking several times during tightening of flywheel to make sure it has not moved.
August 16, 2018 at 6:07 pm #29122andyfrost
ParticipantThat’s VERY sound advice from Charlie , I too , never rely on timing marks , machines of our era have more than likely had various parts swapped during their working life , none more so than Villiers ignition plates.
Your 25c may appear to have ample “suction” , but is your crankcase compression being lost through the main seals.Andy.
August 17, 2018 at 2:46 pm #29126
vhgmcbuddyMemberthanks for the advice
looks like a happy weekend doing timing and compression test. keep your fingers crossed 🙂 -
