Mountfield 11
Home Forums General Help and information Mountfield 11
  • #39300
    fell
    Any one got a mountfield 11
    #39304
    Yes, Mountfield 11 hp, 36″ mowing deck.
    fell
    I’ve just bought 1 and don’t know if it has the correct transmission belt on wondering if you could help
    When the pedal is pressed down it drives but when released doesn’t drive ?
    Working wrong way around I think
    #39313
    The instruction manual says “Your unit has a single clutch/brake pedal that operates both the clutch for changing gears and the brake. Fully depress the clutch/brake pedal to stop your unit.”
    Indeed, your machine seems to be operating the wrong way around!
    The transmission belt goes past a pulley that’s connected to the pedal. Is the belt the correct side of the pulley?
    I’ll add a photo from the parts catalogue.
    fell
    Hi would you have any idea how long the belt should be ? Or a part number ? Thanks
    #39317
    The part number is 37X31. The catalogue doesn’t say what length it is and our tractor isn’t with us at present to measure it.
    The tractor was made by Murray Power products, Ohio, so it’s possibly a Murray 37X31 belt. There’s some online.
    #39319
    I have scanned the maintenance document as a PDF. It explains how to change the drive belt – it looks a bit fiddly and requires looping the belt over the gear lever etc!
    https://staging.vhgmc.co.uk/wp-content/uploads/2022/06/Mountfield-11-Tractor-Maintenance-Document.pdf
    #39320
    fell
    Thanks for your help I’ll have a look tomorrow see if I can work my problem out
    #39373
    There are some numbers written in pen on our Mountfield that relate to the drive belts.
    The deck belt is an A80.
    The drive belt numbers are 13X2032LI and also A2062LD. They may be of some help.
    #39378
    Quite possibly as simple as that !
