Home › Forums › General › Help and information › Landmaster numbering
- This topic has 6 replies, 3 voices, and was last updated 10 years, 2 months ago by
January 1, 2016 at 4:49 pm #15631
vhgmcbuddyMemberHappy new year to all
I have a question does anyone know how to date a landmaster machine I have an old JAP engined 150 serial number 9150708 manufactured in Hucknel with it is letter regarding some spare parts dated 1963 a 1960 price list and a 1962 operators manual so i am presuming that the machine is around that time but how do you arrive at an exact date?January 1, 2016 at 4:52 pm #15632
vhgmcbuddyMemberForgot to mention it was originally supplied by Shukers of Shrewsbury
January 2, 2016 at 9:04 am #15633
charlieKeymasterIf it has the original JAP engine then it should be possible to get the year from the engine number. JAP used a letter to indicate year. See JAP engine numbering
January 2, 2016 at 11:58 am #15634
vhgmcbuddyMemberThank you very much for the link looks like it’s 1959 as it’s a G stamped on the crank case 16H/G/763/2.The original owner must have purchased the plough and Tarpen gear in the 60’s although I surpose the engine could have been in Landmaster’s store for a bit and mounted to the frame in the early 60’s.
One more question has any one got a link to a 16H engine manual?
Regards LenJanuary 2, 2016 at 2:04 pm #15635
trusty220KeymasterIt is quite possible that the engine could have stayed in stock for twelve months or more, either in stock with the manufacturer or with Landmaster. There are some large discrepancies with the Trusty numbering, and it is probably down to the factory “Doing a deal” to buy up any old stock that may be hanging around at the engine manufacturer’s.
A great case in point is the distribution of Norton engines. By looking at the numbering it looks like a large batch of engines (probably war-surplus) was bought and put on the shelf to be used over a prolonged period.
Don’t always use the engine number as gospel- it is a good starting point if nothing else is available, but it can be misleading in such cases.
January 2, 2016 at 5:29 pm #15638
trusty220KeymasterI’ve been having a ferret around this afternoon and all I could find is a very worn copy of a parts list which has a torn front cover with part of the listing for the carburretor missing. The wording on the front says, “J.A.P. Model 16H Two-Stroke engine as fitted to Landmaster Model L150”, so it sounds like the engine that you’ve got.
If you want me to scan it send me a PM with your email address on and I will send it to you as an attachment.
Geoff
January 2, 2016 at 5:42 pm #15639
vhgmcbuddyMemberThank you very much for your help I will PM you shortly.
