Home › Forums › The Machinery Forums › Pedestrian operated machines › Iseki AC-2 rotavator
- This topic has 52 replies, 7 voices, and was last updated 6 years ago by
December 12, 2013 at 2:35 pm #3979
wristpinParticipantPerhaps you need a “bigger drop” of fuel to get her several firing strokes. Try lacing the air filter element with a good dollop of fuel – in the open air and have an extinguisher handy just in case. If you then get a few firing strokes in succession you have proved the point that it’s a fuel supply issue. I’ve got a handy squeeze bottle with brass spout (Partco or Sparex from the local ag merchant) that’s just the job for such occasions.
December 12, 2013 at 5:39 pm #3982
hillsiderParticipantI have found that some maintenance sprays are also good for proving that an engine is able to run, one that i use is marketed by Morrison’s and is around £2 a tin. See tin in attached photo not the chainsaw that is another story all of it’s own. You do have to be experiment to find sprays that work for instance WD40 does not seem to fire up.
December 12, 2013 at 6:28 pm #3985
wristpinParticipantMorris’s Carb Cleaner does.
December 13, 2013 at 10:20 pm #4028
stuartParticipantIt maybe the ignition timing is out.The magneto’s stator assy (the stator is the coil,contact breakers and condensor assy located behind the flywheel) has slotted holes to enable adjustment.
Also worth checking is the exhaust port and the exhaust itself……the engine is a 2 stroke which burns oil and eventually will block the exhaust port in the cylinder barrel and the exhaust outlet with carbon.If the gases cant escape the engine will not run.August 18, 2014 at 7:13 am #9759
charlieKeymasterspam removed
March 4, 2020 at 3:38 pm #33417
vhgmcbuddyMemberHi all, sorry for the zombie thread resurrection. Just joined mainly because I have one of these. Does any one by any chance still have the service manual on file please? I have one but the return springs on the throttle don’t work at all, so need to make sure they’re the right length / in the right order. Starts fine, but if I throttle up, I either have to choke it to stop it or poke the cable attachment downwards with a stick to reduce the revs…
I have a couple of other vintage machines, so hopefully may be able to contribute at some point!
Many thanks in advance,
MiloMarch 5, 2020 at 7:39 am #33419
charlieKeymasterMilo, welcome to the forum. You would be better starting a new topic rather than tag on the end of an old topic.
March 11, 2020 at 9:54 pm #33484
vhgmcbuddyMemberThank you Charlie, I thought this would be a little more inconspicuous… 😉
