Home › Forums › The Machinery Forums › Pedestrian operated machines › Iseki AC-2 rotavator
- This topic has 52 replies, 7 voices, and was last updated 6 years ago by
November 26, 2013 at 7:30 pm #3442
stuartParticipantOK thaks Phil.I am near the town of Kettering in Northamptonshire.If i was around your way anytime i would take you up on the offer.
November 26, 2013 at 8:00 pm #3444
vhgmcbuddyMemberAngus,
Thanks for the information.
Stuart,
Thank you too. I’m in S W Wales. I’ve got a neighbour who used to teach mechanics coming round tomorrow to take a look at it so hopefully he’ll be able to help.
November 26, 2013 at 8:13 pm #3445
vhgmcbuddyMemberFragonard, did you get the email ok ??
November 26, 2013 at 8:19 pm #3446
vhgmcbuddyMemberThank you Paul. Just picked it up. Brilliant.
Will this be of any use to somebody?
November 26, 2013 at 8:38 pm #3450
vhgmcbuddyMemberOk, glad its of use to you !!
November 26, 2013 at 8:49 pm #3452
stuartParticipantOK let us all know if he gets its running for you.
November 27, 2013 at 7:19 pm #3474
vhgmcbuddyMemberStuart, can you email me on paws44@btinternet.com Phil
November 30, 2013 at 8:55 am #3531
vhgmcbuddyMemberHi i have one of there rotavators mine is a 2 stroke
model if you are interested its up for grabsDecember 3, 2013 at 9:59 am #3636
vhgmcbuddyMemberFragonard, please email me. Phil
December 3, 2013 at 2:55 pm #3641
vhgmcbuddyMember“I suspect if your engine does not start it has lost its spark due to standing / not used for a long time ??.If this is the case then the flywheel will need removing to access to the magneto (contact breakers and condensor).You really need a proper removal tool for this flywheel.Do NOT hit the flywheel or the end of the crankshaft with a hammer in an attempt to remove it !!.I used one of my flywheel removal tools and it was very tight on the taper !!.
The carburettor would need a thorough cleaning too i suspect.Where are you located as i could get it running for you.”I’ve given the carburettor a good cleaning but still not running. When you say that the “flywheel will need removing to access to the magneto (contact breakers and condensor)”….what do you mean I need to do once I acess teh magneto? Sorry to be a pain. Thank you.
December 3, 2013 at 10:20 pm #3674
stuartParticipantIs it sparking at the spark plug ??.If not then the contact breakers will require cleaning and the only thorough way to achieve this is by removing the flywheel.
December 3, 2013 at 10:25 pm #3675
vhgmcbuddyMemberIt is sparking at the plug Stuart. Not sure what to do now. Any suggestions appreciated.
December 11, 2013 at 4:03 pm #3948
vhgmcbuddyMemberThis guy who’se a small engine mechanic told me to pour a spoonfull of fuel into behind the air filter. If it then ‘starts’ for a little while or something similar, then it’s a failure to get fuel issue. I did this and nothing. I did get the odd puff of smoke and a slight ‘bang’ but nothing. Does this mean that it’s likely an electrical issue although the spart plug does spark?
December 12, 2013 at 8:53 am #3973
charlieKeymasterIf you are getting some smoke it suggests the spark is making some attempt to burn the fuel. It might be worth fitting a new plug, is the one fitted the correct one and does it have the correct gap? I had a B&S engine with a lovely spark that would not start, a drop offuel down the plug hole and away it went and kept running, now starts with no problem. If it is a fuel issue it may well be a blocked jet in the carb. If it is blow them through with an air line, do not be tempted to poke a bit of wire through to clean them.
December 12, 2013 at 11:11 am #3976
vhgmcbuddyMemberThanks. Yes, I fitted a new plug which is a B6H as specified in the Iseki brochure uploaded to this thread on Page 1. Yes, I’ve cleaned the Carb and the jets and tried dropping fuel down the plug hole but I only get the odd puff of smoke and ‘bang’.
