Home › Forums › The Machinery Forums › Garden implements › Implements at Somerset's Festival of Transport
- This topic has 6 replies, 4 voices, and was last updated 10 years, 2 months ago by
August 12, 2014 at 9:28 am #9644
will-haggleParticipantA good variety of implements were on show at this event, held on 9th and 10th August 2014 at Haynes Motor Museum, Sparkford, Somerset.
Photo 1 is Roy Watts’ French made Vermorel Sprayer, Cooper-Pegler had the rights to these but this one doesn’t have their badge on it.
Photo 2 is my display of sprayers.
Photo 3 is Roy with an unusual spray lance, it has MM logo and a patent no. which I will look up.
Photo 4 is a close up of the trigger with logo.
Photo 5 is a collection of interesting push hoes and seeders shown by a gentleman who normally demonstrates flint knapping. He brought this collection from the attic, it belonged to his father.
Photo 6 is his duplex disc hoe.
Photo 7 is a Boby seeder and a Planet with the round seed container, he’s sure the container is in the attic!August 12, 2014 at 1:52 pm #9680
charlieKeymasterAugust 13, 2014 at 3:40 pm #9700
will-haggleParticipantI found this advert on the Ministry of Agriculture Yearbook 1919….
Here’s a link to the page…
https://archive.org/stream/journalofministr2810grea/journalofministr2810grea#page/n8/mode/1up…and a link to the parent site…
August 13, 2014 at 4:25 pm #9707
will-haggleParticipantNow it looks like I’ve found the patent for that MM spray lance….
https://www.lens.org/lens/patent/GB_513013_A513,013. Valve-actuating mechanism ; nozzles. MARVEN B., and MACPHERSON, A. J. March 29, 1938, No. 9618. [Classes 69 (iii) and 135] A hand-controlled nozzle of the kind in which a spring closed valve is unseated by a rod 15 moved axially by a hand lever 20 pivoted to the forward end of the nozzle body, is provided with a link 23 pivoted at 24 to the lever 20 and bearing on the rod 15, guided substantially along the axis thereof by a pin 21 working in a siot 22, the pivot 19 of the lever being in the line of the axis of the rod. The link 23 is normally at an angle to the rod 15 and so arranged that the toggle system constituted by the link and lever may be brought towards but not beyond the dead centre. An additional spring 25 may be provided bearing against the lever 20.
October 22, 2015 at 1:34 pm #14903
charlieKeymasterspam removed
October 22, 2015 at 1:38 pm #14904
daveParticipantWell done Charlie.
January 13, 2016 at 2:57 pm #15752
vhgmcbuddyMemberCool!
