Home › Forums › The Machinery Forums › Pedestrian operated machines › Howard Gem Electric starter
- This topic has 7 replies, 6 voices, and was last updated 9 years, 7 months ago by
July 19, 2016 at 8:07 pm #21528
vhgmcbuddyMemberHi I am thinking of trying to convert my old Howard Gem to electric (battery) start can anyone give me any advice I have a workshop with milling machine free standing drill screw cutting lathe power saw surface grinder etc. What I don’t have is knowledge of how to make the starter. Can anyone help.
July 19, 2016 at 10:59 pm #21530moggyjim
Participantlook for a dynastarter from a golf cart they are belt driven . A pully can be fixed were the pull cord was mounted.the rest is mounting brackets battery location relay and switch.
July 20, 2016 at 8:05 am #21533
trusty220KeymasterA dynastart is definitely the way to go as it turns the engine over with a V-belt and also charges up the battery at the same time. An alternative source for it could be an old Ransomes Motor Triple with a petrol MAG engine, although they are getting harder to find these days.
July 20, 2016 at 2:30 pm #21534andyfrost
ParticipantJon , you haven’t told us what engine you have on your Gem , if it’s a Kohler it would be relatively straightforward , as has been suggested using a dynastart and removing the recoil system.
IF however you have a Jap or BJ engine , it would be an understatement to say it is more difficult.
Out of curiosity why do you think you need electric start ??.Andy.
July 20, 2016 at 8:47 pm #21538
vhgmcbuddyMemberHi Andy it is a JAP I need a starter as I am getting to old to swing it. Can it be done with a Jap engine.
July 20, 2016 at 10:10 pm #21539andyfrost
ParticipantJon , the problem you will face is that the JAP engine does not have a crankshaft “poking out at the front” the end is enclosed internally. Whether a dynastart is both strong and powerful enough to be connected via the cranking stub I’m not so sure , perhaps folk more experience with these form of starters would know.
July 20, 2016 at 10:43 pm #21540
vhgmcbuddyMemberA jap engine would be tricky, however the way I would go about is to fit a different silencer to it so you’ve clear access to the timing cover, then you’d need to accurately drill a hole in the timing cover in line with the end of the crank, fit to it a crank extension with an oil seal where it exits, then rig up a dyno starter to a pulley bolted to it. Really depends on your skill level or how much you want to spend with an engineering firm. I’d probably be looking for a kohler engined gem myself.
July 28, 2016 at 10:22 pm #21686
vhgmcbuddyMemberI think your wasting your time trying to covert an old engine
I have a kohler gem & thats hard to start sometimes. Easy with the pull start on the front though
