Home › Forums › The Machinery Forums › Pedestrian operated machines › Howard 810 cc
- This topic has 14 replies, 5 voices, and was last updated 1 year, 11 months ago by
February 24, 2024 at 8:51 pm #41840
rexy
ParticipantGood evening all first post 😊. I’ve acquired a Howard gem 810cc rotavator, it hadn’t run for about 5 years, I put some fresh fuel in it and thought it’s never going to go, half a revelation on the crank handle and it fired up to my surprise. Was running lumpy and poping, the carb was flooding out intake side. I have taken the Amal 397 carb apart and the float was Jammed in the downward position cleaned everything up and ordered new float valve and banjo filter . The new one is metal and the original was plastic.when I reassembled the jet it sat abit wonky in the inlet feed thought try the original plastic one back in there and that was the same. Thought might of been crud old tarnish making it sit funny at the dome which the point of jet tip sits in. Cleaned with a cue tip with carb cleaner shiney brass. Do I try find a new bottom float chamber or is the something I’m missing . Also after fitting the metal jet I tried to run the engine but no avail took apart again completely dry in the chamber so now tip not letting fuel through. Is there anyone in the East Sussex area that might be able to come have a look and point me in the right direction and get her going . Many thanks Rex
February 25, 2024 at 8:42 am #41841
charlieKeymasterWhat carb is it? A photo or two would help.
February 25, 2024 at 10:00 am #41845rexy
ParticipantMorning Charlie it’s a Amal 397 carb
February 25, 2024 at 10:06 am #41846rexy
ParticipantAmal 397
February 25, 2024 at 11:35 am #41848rexy
ParticipantFebruary 25, 2024 at 11:36 am #41850rexy
ParticipantThe video doesn’t seem to open for some reason
February 25, 2024 at 12:42 pm #41851
charlieKeymastervideo worked for me. A side on photo of carb will help identify what float bowl looks like.
February 25, 2024 at 1:44 pm #41852john-e-w
Participantvideo worked for me – about 10sec duration
John E-W
February 25, 2024 at 2:48 pm #41853rexy
ParticipantFebruary 26, 2024 at 10:59 pm #41856davidbliss
ParticipantEngine sort of sounds ok apart from the spitting back that’s not quite like an ignition type fault sound causing the spitting, I have had early veteran car engines do something similar as the inlet valves are atmospherically opened and not mechanical, you have to get the valve spring strength fine tuned, to strong and you loose power and to weak they can sort of give a double skip bounce and spit at a particular throttle opening, and a sticking valve or broken valve spring can also causes same symptoms, I did have a valve insert start to drop out on a alloy head, it didn’t spit but just like a intermittent ignition fault causing shorted ignition. I have just had a thought valve timing, if the engine sparks at every top dead centre what I call a lazy spark if the inlet is opening early and exhaust is closing late they can spit back so check valve clearances are correct and are rocking at pistons dead top centre.
February 27, 2024 at 7:04 am #41857rexy
ParticipantThank you for some information David I will check the valve tolerances next time I’m down the shed. I’ve found some information on the web does 0.006 sound about right for inlet and outlet clearances? Many thanks
March 2, 2024 at 12:43 pm #41870rexy
ParticipantJust a update, I have changed ht leads around on the distributor cap and found the tank filter was blocked. Petrol Wasn’t running at a flow.cleaned out tank and fuel tap reassembled and she’s purring along now ! 😀 many thanks for the replies
March 3, 2024 at 12:07 pm #41875rexy
ParticipantAfternoon all,could someone tell me or how to find out what date the gem was made? The serial number is
G48494 many thanks jamieApril 3, 2024 at 10:56 pm #42016shayman
ParticipantHi, just acquired one of these machines and think that the chain adjuster is not complete. Does anyone have a picture of inside the chain case so I can see if anything is missing. Will post pics if required.
Thanks MarkApril 4, 2024 at 8:11 am #42017
charlieKeymasterMark, please start a new topic to avoid confusion.
