Home › Forums › General › Help and information › Help needed, Mountfield M1
- This topic has 20 replies, 8 voices, and was last updated 8 years ago by
February 23, 2018 at 9:58 pm #28032
vhgmcbuddyMemberHello.
I am a new member and have found this old rotavator.
I have spent hours on the web trying to find the name and mod.
I think it is a Mountfield M1 super estate 4hp heavy duty 4 blade.
I was wondering if any members could confirm this and also the age of it.
Would you recommend refurbishing it or just service and get it running ?
Thank youFebruary 24, 2018 at 10:23 am #28035
charlieKeymasterJohn, welcome to the forum. Unfortunately I cannot help with date. To refurbish or just service very much depends on what you intend doing with it and what condition it is in. If anything mechanical or electrical (ignition) needs replacing or repairing that would be first priority. To give it a full restoration and paint job is personal preference.
February 24, 2018 at 10:43 am #28036
vhgmcbuddyMemberThank you Charlie.
I think I’ll make sure it’s ok mechanical and it works before I give it a paint job.
Hoping someone will know date and also the Mod.No. so I can see if there is a manual for it.
I did email Mountfield but had no reply.
Cheers
John.February 24, 2018 at 12:18 pm #28038
alanParticipantJohn
There’s some info on the old forum archive which may be of help:
https://www.tractorbox.co.uk/forum/forum_posts.asp?TID=757
Also found this reference from the early 1970’s. “an M1 Super at around £116 with a 3 h.p. engine, there are the Estate at £130, fitted with a 4h.p. engine, and the Monarch at £140.50, fitted with a 5 h.p. engine”.
Mountfield is now owned by another company so information or archives may no longer be available or may be lost.
Alan
February 24, 2018 at 3:59 pm #28039
vhgmcbuddyMemberThanks Alan.
I think its the Estate but just got engine off and it looks like it may be American.
The quest goes on.
John.February 24, 2018 at 4:31 pm #28040
alanParticipantThat’ll be a Tecumseh or Aspera engine then?
February 24, 2018 at 6:31 pm #28041
vhgmcbuddyMemberYes you were right Alan just found the plate on the engine and I can see it says Aspera. Can’t read the rest but I’ll have a good look when its cleaned.
Bit worried now may need to strip the engine as I can turn it over bye hand with the spark plug in.
Is this normal do you think ?February 24, 2018 at 10:56 pm #28042
hillsiderParticipantBy courtesy of the folk at allotment- garden there are some free to dowload manuals on there website
I can confirm that you have an M1 there but as you have found you have an Aspera engine fitted rather than the Briggs and Stratton engine that mine has fitted. If you can find the model and serial numbers on here it is possible that one of the forum members can help with some seful information.
February 25, 2018 at 8:57 am #28043
vhgmcbuddyMemberThanks hillsider, very useful downloads from allotment org.
I am wondering now why I have an Aspera and not Briggs.
Was it made like that by Mountfield or has it had an engine change at some time. ?February 25, 2018 at 9:11 am #28044
charlieKeymasterIs there any evidence around frame of machine where engine mounts to suggest it had something different previously? Aspera may have been a later option. Yes it should be possible to turn engine by hand with plug in, you should feel it become harder at some point as piston comes up on compression stroke. If engine has been stood for a long period one of the valves could be stuck open which would cause loss of compression.
February 25, 2018 at 10:07 am #28045andyfrost
ParticipantI’m fairly certain the Aspera (LAV 35) was fitted with a decompressor , which would account for feeling lack of compression. That model was fitted with both the Briggs and Aspera from new.
February 25, 2018 at 11:29 am #28046
vhgmcbuddyMemberAt last I have finally got to see the No.s on the I.D plate.
They are LAV 35. 3272368 Does this mean its a 1968 engine.?
Think I’ll get it going if I can before I start stripping down the engine as it has a decompressor and was fitted as new like andyfrost says above.
I can’t see Aspere listed on the allotment org site.February 25, 2018 at 12:34 pm #28047mickattwo
ParticipantI thought Aspera m/c’s were Italian
Put a search on Google for the manualFebruary 25, 2018 at 1:43 pm #28049
charlieKeymasterHot of the scanner, copy of user instructions.
February 25, 2018 at 2:20 pm #28051
dorignyParticipantMy Uncle had an M1 identical to this one. His was fitted with Aspera at new, which was an early casualty, he then replaced it with a Briggs 3.5Hp.
His was identical with the central drive engagement lever. More recent models had a handlebar clutch lever and jockey pulley.Clive.
