Home › Forums › The Machinery Forums › Pedestrian operated machines › BMB Ploughmate question
- This topic has 6 replies, 4 voices, and was last updated 7 years, 4 months ago by
October 17, 2018 at 6:05 pm #29441
vhgmcbuddyMemberA quick question if I may;
Does the BMB Ploughmate have a reverse gear and a differential, ie not a sold fixed drive axle.
Thanks in advance
DaveOctober 17, 2018 at 7:57 pm #29443
charlieKeymasterDave, the BMB Plowmate has two forward and one reverse gear. Not sure about axle, it may have independant clutches for steering, dont think it has a differential.
October 17, 2018 at 8:10 pm #29444
vhgmcbuddyMemberMany thanks Charlie.
I’m looking for a machine to participate in ploughing matches. I regularly see Trusty’s and Anzani’s, I thought a BMB or Barford would be a little different.October 18, 2018 at 7:52 am #29445
trusty220KeymasterThe Plowmate does have a differential which makes it very good at turning and manouvering in tight spaces, but the one thing it does not have is a diff lock to lock both wheels together. This results in the machine having a tendency to spin the landwheel constantly and it is nearly impossible to keep in a straight line when you encounter normal field conditions. It works fine on well-tilled ground (which is what it was designed for) but these days most ploughing matches are held on open fields with hard, compacted soil.
Both the Trusty and the Anzani will cope with these conditions because they have a positive drive to both wheels and you have to disengage a wheel to turn them (i.e. neither has a differential).
That is why these machines dominate so much; if you want something different have you thought of a two-wheeled Garner tractor? They are hard to find but are certainly unusual.
October 18, 2018 at 8:36 am #29446
charlieKeymasterThe Barford would struggle even with wheel weights, the plough also lacks fine adjustment. Again not really designed to plough hard ground. Other machines that should cope with ploughing match conditions are Rototiller 56 or Rowtrac although neither has a great degree of adjustment on the plough.
October 18, 2018 at 4:24 pm #29447andyfrost
ParticipantI can personally vouch what Geoff says , my Father-in-Law had a BMB , and it was my TASK to plough his land with it , there were times when I would rather have been armed with a spade , they are very difficult to handle , unbalanced , and as Geoff says , almost impossible to keep in a straight line.
The plough itself on a Trusty is in a class of its own , but remember most trustys lack reverse.
Others to consider are a Clifford , which has a multi adjustable plough very similar to the Trusty.The Howard 700 is a very underated machine ploughing wise , reverse gear , and a seperate difflock……..food for thought perhaps.Andy
October 24, 2018 at 12:58 am #29468
vhgmcbuddyMemberMany thanks for your comments and contributions guys.
I’ve bitten the bullit and secured a Plowmate, it’s on spade lug wheels and in excellent unmolested condition.
I’ll post pictures when I get her home and stabled.Dave
