Home › Forums › The Machinery Forums › Ride-on machines › Aquired a Ransome MG2 and I need some help
- This topic has 10 replies, 4 voices, and was last updated 8 years, 6 months ago by
expeatfarmer.
September 7, 2017 at 3:53 pm #26413
vhgmcbuddyMemberHi there,
I’m new to this forum and I’m also hoping that someone out there can assist me with my latest acquisition, which is a Ransome MG2. The engine is seized (not an issue) but no mag or front cover although I have the timing chain and sprockets. also the cooling fan housing will need to be replaced as it is pretty bad condition (rotted through)
Can anyone point me in a direction for possible spares etc. I can make several things as I have a lathe and milling machine but other things could be a problem !!!Many thanks old50mm
September 7, 2017 at 5:39 pm #26414
ransomes256ParticipantSend me an email and I am sure I will be able to help you out.
njarrett@btinternet.com
NeilSeptember 8, 2017 at 9:52 am #26416expeatfarmer
ParticipantI have various spares covers manifolds etc make a list of what you need.
September 8, 2017 at 11:10 am #26417expeatfarmer
ParticipantI have a cooling fan and housing spare.
September 8, 2017 at 11:43 am #26418
daveParticipantI have a MG2 service/handbook I can pdf download to you
if you need it.September 9, 2017 at 9:33 am #26420
vhgmcbuddyMemberHi there expeatfarmer,
Many thanks for your reply to my question. At present I need a new cooling cowl complete, a timing chain front cover (cam to mag drive) and possibly a magneto if you have one. I am aiming to remove the engine and primary gear box possibly today and this may reveal yet other parts that require replacing????Let me know what you have and can do and cost and I will reply asap.
Many thanks again
Peter
September 9, 2017 at 9:36 am #26421
vhgmcbuddyMemberHi Neil,
My email address is peter@jantar.plus.com. Any type of assistance would be greatly appreciated.Peter
September 9, 2017 at 9:51 am #26422expeatfarmer
ParticipantHi peter I do have a fan assembly and a timing case cover. I do not have a whole magneto, I have a body and rotor which Neil may be able to restore for you if he does not have a whole unit.
JonathanSeptember 9, 2017 at 10:08 am #26423
vhgmcbuddyMemberWow what service this is !!!! I will gladly take the offer of the cooling fan and front cover. I do have a Lucas SR1 Magneto which may fit I’m not sure as yet as I have not got that far. Can you let me know cost etc and I will arrange with you. Mob 07974698051
Peter
September 9, 2017 at 10:31 am #26424
vhgmcbuddyMemberHi Jonathan, one thing I meant to ask, do you have or know where I could get a cylinder head gasket from ?? Or can some form of substitute be used ??
Peter
September 9, 2017 at 6:12 pm #26427expeatfarmer
ParticipantI have a spare used head gasket which if annealed will be fine, Neil may have new ones they are solid copper about .75mm thick.
